9070 Smart Vibration Meter
TPI offers the 9070 vibration monitoring and analysis tool
Image of TPI's 9070 Smart Vibration MeterTPI's 9070 smart vibration meter offers vibration analysis at the touch of a button and analyzes and interprets readings. Overall machine and bearing conditions: vibration values are displayed with color-coded alarm levels for ISO values and Bearing Damage (BDU).
The 9070 is a simple-to-use vibration monitoring and analysis tool that allows easy display of vibration signals. The meter automatically per-forms vibration analysis functions based on machine running speed to help diagnose faults such as unbalance, misalignment, and looseness.
The system is designed to enable a user to take vibration measurements from assets (e.g. pumps, motors, fans, and bearings). The unit displays vibration frequency plots and allows vibration severity and bearing condition to be monitored.
Features and Benefits
  • ISO built-in alarms
  • Identifies bearing problems with BDU reading
  • Identifies problems with built-in band filters
    • 1X (unbalance)
    • 2X (misalignment)
    • 3X (looseness)
  • 800 line FFT (spectrum)
  • Ruggedized IP67 case
  • 3-year limited warranty
  • Full-color OLED display
  • Built-in accelerometer with stinger. Optional long stinger and magnetic mount available
图片制造商零件编号描述配套使用/相关产品重量可供货数量价格
VIBRATION TESTER COND BASED MON9070VIBRATION TESTER COND BASED MON基于状态监控0.618 磅(280.32 g)11 - 立即发货
248 - 厂方库存
1 : ¥4,739.01
查看详情
发布日期: 2014-02-19
